achillesuk's avatar
achillesuk
Is it better to power off NAS the hours I'm not using it?
Hi,
I've a ReadyNas Duo v2. I had it all 99% of the time, but I recently decided to switch the timed switch on/off. However now I've noticed some SMART errors
Detected increasing pending sector count on disk 2 [68, 66]
Detected increasing uncorrectable errors on disk 2 [65, 0]
Mainly those occur when it wakes up.
Anyhow, I'm ordering a WD Red (3tb) to backup and replace the existing one (WD Green 3tb).
My question is, is it better to auto-off the NAS at the times I'm not using it? i.e. when I'm sleep or outside, which roughly are 50% of the time...or is it better to switch on and off?
  • StephenB's avatar
    I don't think the disk failures are directly related to the power-off. The NAS does a volume scan when it boots, and I suspect that the volume scan is simply uncovering the disk failure.
    If you don't have a backup, it would be a good idea to create one now (while you are waiting for the WDC Red to arrive).
    To your main question - assuming you have a regular schedule, I don't think it matters if you use the timer or manually turn the system on/off. The practical advantage of the timer is that you won't forget.
    That's what I think too.
    I've only got about 550gb left so it's not enough. Any ideas on this?
    I mainly do this for power consumption and HD life extension. (a bit late now though :P )
  • StephenB's avatar
    Leaving the NAS on, with a conservative disk spindown setting is another approach. The NAS itself doesn't draw much power, and if you aren't using it during the day you will get additional power savings. Perhaps a 30 minute threshold - you don't want the disks to be spinning up frequently. I'm not sure how any of these options this actually effect HD life. Spinning the drives up creates more stress than keeping them spinning, so there is a trade-off here. However, the options do save power.
    On the backup, of course you could attempt to save "critical" data on the space that you do have. Or get another USB drive.
ProSupport for Business
