Rustie-
Feb 14, 2020Aspirant
Is it possible to use a ReadyNAS Duo v2 as Direct Attached Storage (DAS)
I need to know if it is possible to use a ReadyNAS Duo v2 just as a Direct Attached Storage (DAS) device as opposed to a NAS. Strange question I know. However, I'm not an IT pro by any means, but fro...
Feb 14, 2020Guru - Experienced User
No, you can't. If you were to get a new NAS, you could repurpose your old Duo as a backup device (using rsync backup jobs).
Rustie- wrote:
I can log onto it through the IP address over the inernet so I can view the files stored on it but I can no longer save files to it making it pretty useless.
I am assuming you mean "over your home network", and not "over the internet".
What firmware are you running?
You should be able to store files also - I am suspecting you have a credentials issue on the PC. Can you try running the command prompt on the Windows PC, and entering
net use * /delete /y net use t: \\nas-ip-address\C /user:admin nas-admin-password
using the real NAS IP address and admin password of course. Be careful on the typing (the spaces and the slash directions matter).
The first command will terminate any open network sessions, the second attempts to map the NAS data volume to drive letter T. Note this won't work if the NAS is still using the default admin password.
Rustie-
I will give this a go and check the firmware version when I get home from work.
