Rustie-
Feb 14, 2020Aspirant
Is it possible to use a ReadyNAS Duo v2 as Direct Attached Storage (DAS)
I need to know if it is possible to use a ReadyNAS Duo v2 just as a Direct Attached Storage (DAS) device as opposed to a NAS. Strange question I know. However, I'm not an IT pro by any means, but fro...
schumaku
Feb 14, 2020Guru - Experienced User
Rustie- wrote:... from what I have read on various forums trying to find a solution I understand that Microsoft have stopped supporting the SMB1 file sharing protocol recently due to security vunerabilities. ...
This is not correct. The effecive vunerabilities for SMB 1.0 on Windows and Linux/SAMBA were fixed essentially almost before the big noise whent through the media years ago.
SMB 1.0 transport protocol and the NetBIOS name resolution and discovery is still readily available on the latest Windows 10 system builds.
Rustie- wrote:As the Duo v2 uses this protocol and presumably, because Netgear have also stopped supporting this system becasue let's face it it is getting a bit old, I can no longer see my device as a drive within file explorer.
The the Duo v2 was discontinued in 2013. Netgear ended firmware updates for both models in 2017 (similar to Microsoft ending support for Windows 7). Netgear released a firmware update back in 2017 also for your NAS addressing the CVE-2017-7494 vulnerability which allowed to access and write to any shared folders even if the users wasn't authorized.
The "big" vulnerability was fixed on both Windows and SAMBA source code - and deployed https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc. Still, and shared folder legally accessible on a NAS, a Windows PC or Server, on a business class storage systems, ... can be encrypted by malware. Dropping SMB 1.0 does not change a s**t.
I won't talk of the fact that SMB1 isn’t modern or efficient - many features have made it to the higher protocol versions. Some would (massively) help on these underpowered NAS system like yours - however, it has never happened. Other features are simply out of scope, like protocol signing or encryption
Enabling the CIFS/SMB 1.0 feature can be done in a very easy way on the Windows 10 systems: Just add/enable the CIFS/SMB 1.0 Client feature.
There are many legit reasons why users can and must continue using the SMB 1.0 [Items 1..3 stolen from a Microsoft blog, and extended:
- You’re still running XP or WS2003 under a custom support agreement.
- You have old management software that demands admins browse via the so-called ‘network' aka 'network neighbourhood’ master browser list.
- You run old multi-function printers with old firmware in order to “scan to share”.
- You operate legacy storage systems, legacy NAS models, ... only supporting SMB 1.0/CIFS.
FWIW - I've borrowed most of my reply from my own posts here in the community.
So all you have to do is to enable the Windows [7,8,]10 feature (type: "feature" in the Windows search!) for the user friendly control, scroll down to "SMB 1.0/CIFS File Sharing" - required is only the "SMB 1.0/CIFS Client". Let it rattle, reboot the WIndows system - and ta-taa your Duo v2 will be discovered again, and the file share access is back.
Send beer or money 8-)
Rustie-
I've looked at this before due to post I read on another forum, but SMB 1.0 just doesn't exist in the Windows Feature list on my machine. I've opened up all the sub files in the list, just to check, it's just not there anymore.
- StephenBFeb 14, 2020Guru - Experienced User
Rustie- wrote:
So all you have to do is to enable the Windows [7,8,]10 feature (type: "feature" in the Windows search!) for the user friendly control, scroll down to "SMB 1.0/CIFS File Sharing" - required is only the "SMB 1.0/CIFS Client". Let it rattle, reboot the WIndows system - and ta-taa your Duo v2 will be discovered again, and the file share access is back.I've looked at this before due to post I read on another forum, but SMB 1.0 just doesn't exist in the Windows Feature list on my machine. I've opened up all the sub files in the list, just to check, it's just not there anymore.
SMB 1 is enabled on your Win7 machine, unless you ran specific commands to disable it.
Can you try rebooting the PC and re-entering the commands I gave you above? You can also change C to a share name.
Also, are you running internet security software on the PC?
- Rustie-Feb 14, 2020Aspirant
I understand what you are saying but this isn't a problem that has happened just now, I first noticed it a couple of months ago. I don't use the NAS every day, it's used as a back up for my files and photo's etc. rather than it being used as a full system back up every time I switch my pc on, so the PC and the NAS have both been rebooted numerous times since I first noticed I couldn't see it as a drive in explorer, it makes no difference, I still can't see the NAS as a drive. I definitely haven't disabled anything myself that might cause this issue.
I am using internet security on my pc, but it's the same software I've been using for the last couple of years without any problems, so unless an update a couple of months ago caused a conflict I'm not sure why that should now be causing the problem.
- StephenBFeb 15, 2020Guru - Experienced User
You should rule that possibility out by disabling that software and then trying the commands I gave you again. Some internet security software will block SMB 1 access by default, and it is possible that your software was updated to do that.
If you don't use the NAS much, you could also enable FTP access for the shares, and use an FTP client like FileZilla or WinSCP to access the shares. Though we should be able to get SMB 1 to work, FTP would give you an immediate way to upload and download files.
