raminmd
Feb 17, 2015Aspirant
Is RSYNC frozen..no status.
Hi all, I am backing up via rsync to a ReadyNAS PRO running RAIDator 4.2.9 from a ReadyNAS 516 running 6.2.0. The pro is pulling data from the 516. Here is the problem. There are a few thous...
Feb 17, 2015Guru - Experienced User
Also, generally it is faster if you run NFS first, and then edit the backup job to rsync and then run it again.
