mlbiss
May 18, 2018Aspirant
Is there an upgrade/replacement path for Ready NAS 102?
I'm not sure I've done these tags right ... I bought my unit in 2014 and I believe the warrenty expired last August. In November, I needed to get a new drive. The process was slow but effective!
Yesterday I powered on the unit and it was not accessible. The router sees it when it is booting/booted but then it drops off and disappears.
So ... sadly I'm thinking I need to replace it. Is there a current model that is good for the home? I'm using about 1/2 of 3 TB right now and have the existing using unit setup for RAID 0 (? 1:1 copy). And would this possible replacement be able to use my existing drives?
&/or do you all have any other advice for me?
bedlam1 wrote:
This may be simple to resolve by just replacing the Power Supply Unit, it sounds as if your current one is failing
A "risk buy" of a compatible power brick is worth a shot. If you google AD8180LF 332-10318-01 you will find several inexpensive options.
If that fails, then the RN212 is the currently shipping entry-level home NAS - faster and with more memory. You can directly migrate your disks to the new unit.
- bedlam1Prodigy
- mlbissAspirant
Thank you !!!
