edecanus
Sep 26, 2016Aspirant
iSCSI Expand Successful but Not Provisioned
iSCSI existing 2TB MBR disk with lots of data (dB, mail) expanded successfully to 3TB leaving the existing 2TB and 1TB of additional space. I am unable to use a commercial product or Windows disk mgt to convert the MBR to GPT to truely expand the existing iSCSI disk to 3 TB.
Other then creating a new iSCSI disk with 3TB and formated to GPT and copying the data over, what options are there to make the additional 1 TB of space available to truely expand the existing disk?
Thanks...
- JohnRoNETGEAR Employee Retired
Hi edecanus,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- JennCNETGEAR Employee Retired
Hello edecanus,
If you are using GPT, you can turn it offline to expand. The MBR format is limited to 2TB so I think there is no option but to delete and convert to GPT.
Welcome to the community!
