mnatiello
Dec 18, 2013Aspirant
ISCSI login timeout from remote IP
I am trying to connect to a LUN on my readynas rn10200 via open-iscsi. When the client is in my local network, the connection goes smoothly. From outside the LAN, the connection fails. The NAS sits...
mnatiello
Dec 19, 2013Aspirant
[SOLVED]
Apparently the problem is that the target declares its own address with the LAN number (the only one it knows).
open-iscsi then uses that number for login, despite the fact that the discovery of the target was possible because
of the WAN adress of the router hosting the target.
The solution is to edit by hand all references to the LAN-address in the database, replacing them with the
WAN-address. Then
iscsiadm -m node --login
properly connects to the target.
M.Natiello
WAN-address. Then
M.Natiello
