d_rick
Feb 25, 2012Tutor
iscsi won't authenticate / reconnect to w2k8r2 x64 host
hi, looks like a lot of people are having similar issues to mine, but i don't see any solutions. i created an iscsi share on my RNDP6000 running .19 code. it worked fine for several months, but...
d_rick
Mar 03, 2012Tutor
Grievous wrote: I just checked a 2008 and a 2008r2 system(ran windows update about an hour ago), neither are having an issue connecting to an iSCSI target with CHAP enabled using the windows initiator.
Have you verified that you don't have some sort of network connectivity issue going on?
Grievous, not sure how NW connectivity could be the culprit here when just turning CHAP authentication off "fixes" the problem and the connection comes up, stays up, and is rock solid. i've also been hammering the connection doing a level 0 backup for the last few days, and it seems to be reliable at this time.
