cerjzc
Jan 15, 2015Tutor
Issue with new beta 6.2.3-T1652
I tried upgrading one of my devices today from 6.2.2 to 6.2.3 beta. This is a Pro 2 which I have been running on OS 6 since early 2014. The upgrade seemed to go fine and the system rebooted and I wa...
cerjzc
Jan 16, 2015Tutor
No I don't believe it changed. I have it set to static and if I recall correctly it showed the same in Raidar when I tried to connect. And I could connect right after the reboot and move around the frontview pages for close to a minute before that message about "Connecting to ReadyNAS Admin Page..." came up and after that any further attempt to reconnect would go directly to that connecting screen with the progress bar moving across. I did a complete power off and disconnected the power cable to make sure I got a clean boot as well, but it acted the same. Initially I could connect and do actions, but soon it would fail. In fact I wasn't sure I would be able to get to the firmware loading page, but I had just enough time to browse to the 6.2.2 image and upload it before it failed.
Jeff
Jeff
