cerjzc
Jan 15, 2015Tutor
Issue with new beta 6.2.3-T1652
I tried upgrading one of my devices today from 6.2.2 to 6.2.3 beta. This is a Pro 2 which I have been running on OS 6 since early 2014. The upgrade seemed to go fine and the system rebooted and I was able to reconnect, but soon after connecting to Frontview I started getting these messages:
Connecting to ReadyNAS Admin Page...
it would sit at that screen as the progress bar would go completely across without going back to the Frontview. I was still able to connect via ssh and rebooted the device. I found that Frontview would work for the first 30 seconds to maybe 2 minutes before I would get the connecting message again.
I was able to get frontview to work long enough after a reboot to downgrade back to 6.2.2 and everything seems to be working fine again. Just wanted to give a heads up in case someone else is seeing something similar or was thinking about trying this beta.
Jeff.
Jeff.
- cerjzcTutorJust to close this issue out. The 6.2.3 beta 3 did appear to resolve the problem. I let it run for several hours with no issues and then on my Pro 2 I did go ahead and upgrade it to the newer 6.3.3 beta and it also appears to be working fine as well.
Thanks,
Jeff - dhonzikAspirantYou might want to consider upgrading to 6.3.3 beta, I have been running that on Ultra 4 plus with no problems
- ahpsi1Tutor6.2.3 beta 3 fixed mine also. Haven't tried 6.3.3 yet and unsure if the Transmission bug affected anything. Backed up the system to an NVX but I forgot about limiting what it backed up and it filled the NVX up with snapshots (I believe). In any case the beta worked for me.
Thanks!
