proteinnerd
Jan 09, 2017Aspirant
Issue with Raidiator 4.2.30 and some addon services not working
Hi, I recently upgraded to the new 4.2.30 as prompted for my ReadyNAS Business Pro. This caused a number of my addons to stop working including SickRage and SABnzbd and I think PLEX but not ...
- Jan 27, 2017
I gave it another try today.
Updated to 4.2.30
Services all failed to start initially.
Reinstalled
Python (which appeared to be working fine, not sure if I did this last time) - no issue, started fine
SABnzbd - no issue, started fine which was different to last time and encouraging
SickRage - wouldnt start, deleted...failed to delete, reinstalled again...finally worked.
Apart from slight issue with SickRage not deleting, I'd recommend reinstalling python even though it shows as working in the addons page....seems to have been what was causing my issue.
Thanks to those that offered help.
Jan 25, 2017Guru - Experienced User
proteinnerd wrote:
Any thoughts then as to why upgrading to 4.2.30 would lead to services not working and rolling back to 4.1.28 makes them start working again?
One poster found that upgrading glib6 using this add-on solved the problem with sickrage: https://rnxtras.com/add-ons/update/glibc6-2-13-readynas-os-4-x86-only-60494
I believe he updated the library, and then reinstalled it.
His system had other issues (and did have a full root partition), and eventually he upgraded to OS 6.
proteinnerd
Jan 27, 2017Aspirant
Updated to 4.2.30
Reinstalled
