mlight
Dec 03, 2015Aspirant
Issue with ReadyNas NV+ after changing a drive
Yesterday I swapped out the 4th drive in my ReadyNas NV+. I got a number of emails from the NAS. - Disk remove event occurred on SATA channel 4. - Disk fail event occurred on SATA channel 4....
Dec 03, 2015Guru - Experienced User
The drives have a 3 year warranty, are they still covered?
In terms of how to proceed - I'd power down the NAS and test all the drives with WDC's lifeguard program in a PC. Label by slot of course.
You can also try booting the system w/o drive 4 (power down before you remove it).
Do you have a backup of the data?
- JennCDec 03, 2015NETGEAR Employee Retired
Hello mlight,
Please download the logs.
Can you also please check what you get under Volumes > Volume Settings? Post a screenshot if possible.
- mlightDec 03, 2015Aspirant
I can't get to the readyNas NV+ to get the logs.
I haven't shut it down yet.
The othere 3 drives are fine. I just picked up this drive last week, so I can return it there.
Hello mlight,
Have you already tried booting without the disk 4?
