vip_48
May 06, 2018Aspirant
Issues Accessing folders afters 6.9.3 update
I no longer can access my device folders via ip address since 6.9.3 update. The bar loads half way and then stops, but i can access the hard drive via my tv look at files saved.
I am accessing to o...
- May 10, 2018
Hi vip_48
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
May 06, 2018Guru - Experienced User
vip_48 wrote:
I am using a Mac and chrome browser via the ip address. I know ftp access is easiar but how can I site that up on my Macbook and
Actually the simplest (and fastest) way to access the files is to use Finder. The underlying protocol can be either AFP or SMB (and you can just enable both on the NAS).
