bubu
Oct 17, 2015Aspirant
Issues since 6.4.0 upgrade on RN516
Hi I have big issues since upgrade in 6.4.0 on my RN516 : - External USB if connect freeze NAS on startup - Root disk space is 90% - can't unistall application then really not stability...
- Oct 17, 2015
Contact support
bubu
Oct 26, 2015Aspirant
Hi
I contacted Netgear Support : they solved my problems on RN516 since 6.4.0 update. :)
Then do the same contact them :)
RNASguy
Oct 26, 2015Luminary
Glad it worked out for you.
But, what did they do to fix your box.
bc
- Netrage2Oct 30, 2015Aspirant
Lots of people with this issue but nobody posting how the problem is resolved.
Worried that I will lose a chunk of my data as it started doing this half way through my weekly backup.
- bubuOct 30, 2015Aspirant
Hi all
I didn't see what support done but it was an issue for me root folder more 90% and also corrupt config
Then clean all of them and I needed to config again services and backup but never loose data ;)
- Netrage2Oct 31, 2015Aspirant
Update:
Overnight the NAS seemed to complete the reprocess of the snapshots and the NAS let me access it fully this morning. I have since removed all existing snapshots and stopped any new ones from being created.
Looking at the logs, the event that keeps repeating for the time period that the NAS was unusable is related to reprocessing of the snapshots so it looks like any other request to the NAS be it for data access, admin access or even for it to reboot was ignored due to the overloaded work that the firware update had started. Now that work is finished the NAS seems to be usable again.
The only advice I can give to others with the same issue is to try and remove any existing snapshots, stop new ones being created and leave the NAS on 24/7 until it becomes stable.
