browerjs
Nov 22, 2016Apprentice
Issues with NV+
I have been using my NV+ for several years without issue, but the other day when trying to access it, I lost all access to my shares and it was reporting 0MB/0MB in frontview. On the NAS display, it...
- Nov 22, 2016
It does sound like a filling OS partition.
A Netgear Mod could offer courtesy help; other options include (paid) per-incident support from Netgear, and booting the system into tech support mode yourself, and useing telnet to access the system. That last option requires that you mount the OS partition manually.
Another approach is to connect the disks to a PC, and back up the remaining data. Then do a factory reset/rebuild the NAS. R-Linux for windows is one tool that I've heard will work. Or use a linux "live cd" and this procedure: http://home.bott.ca/webserver/?p=306
browerjs
More progress, had to run the command with the path (my unix is very rusty).
My os is indeed full:
/dev/hdc1 1.9G 2.0G 8.9M 100% /sysroot
when I do a:
/sysroot/usr/bin/du -csh /sysroot/var/log/*
It looks like the offending file is
1.5G /sysroot/var/log/upnp-av.log
which is 1.5G of my 1.6G of log files.
should I just delete this using rm?
Nov 22, 2016Guru - Experienced User
echo > /sysroot/var/log/upnp-av.log is better. The file will still be there, but it will be empty.
- browerjsNov 22, 2016Apprentice
Awesome did that and now getting:
/dev/hdc1 1.9G 473M 1.4G 24% /sysroot
Do I need to do a umount now?
Is it umount /dev/hdc1 or umount /sysroot
And then do I just hold down the power button on the unit to reboot?
Thanks for all your help. My fingers are crossed this will work :)
- StephenBNov 22, 2016Guru - Experienced User
Not sure if you need the umount, but it would be umount /sysroot
shutdown -h -now should do a clean shutdown, then you can power up as usual.
So that fixed Frontview after doing another firmware reinstall, but I still can't access my shares. I'm getting a username/pw prompt. Looks like it wants to use my local pc as the domain.
On my Mac, i used to just connect as guest, but that isn't working... I'd imagine there is something I'm missing something in the setup, just not sure what.
