tcatech
Sep 26, 2014Aspirant
Issues with Ready NAS 314, destination is read-only
Issues with Ready NAS 314, destination is read-only. Firmware 6.1.9 Seagate 4TB USB 3.0 HDD ST4000DM NAS set up with 3 shares (Tech, Manager and Marketing). Our marketing department has 5 users t...
XAffi
Nov 09, 2014Aspirant
Hi all,
I have a similar/same issue with my RN104. I made my Backup on an external WD 1TB 3,5" hard drive (USB2). It works well for all shares except one. It tells me that the destiination is read only. I assume the backup is finished, because it occures at the end (just my assumption). I am not sure if the external drive is meant be "destination". However --- It says backup is fail. Any idea how to figure out where it comes from?
BTW: I checked the harddrive on my local WIN machine, without any error.
Checking the logs in /var/log/frontview/backup:
status_backup_009:
BACKUP_STATUS__FAILED!!1415532530!!warn
and backup_009_copy.1415532530.log does not look different than for the other shares... It contains only one "interesting" line : "BACKUP_INFO_LOG_TRUNCATED:257630". But this seems nothing critical. Any additional ideas?
Thanks in advance.
Norbert
BTW: I got snmp data errors while the USB bcakup is running.. Is this usual?
status_backup_009:
Thanks in advance.
Norbert
