jeremyotten
Mar 10, 2012Aspirant
Its all so quiet....
While QNAP / Thecus and Synology are all releasing new hardware en supercool firmwares... its all so quiet at the Readynas section..... What are you guys cooking??
calapso
Apr 04, 2012Aspirant
jeremyotten wrote: While QNAP / Thecus and Synology are all releasing new hardware en supercool firmwares... its all so quiet at the Readynas section.....
Hi
Just had a look at Synology product after your reference and yes...it looks good. I may consider getting this if Netgear carry on with 'scratching their hed" support with my customer's ReadyNAS NV+ V2 (4 bay with 2x2tb drives)
The V2 interface in...hmmm.ok but main problem was that it did not accept/keep/remember a hostname that was entered. Other little gripes were you click on 'download logs' (to send to support) but the button does not appear to do anything nor does it tell you where it downloaded the log to if indeed it did work. No facility to enter a proxy so cannot check for updates online from a secure network!
Thanks for the heads up, jeremyotten..you played with Synology? If so let me know what you think?
Calapso
- Aug 06, 2024Retired_Member
