saxguy1
Oct 10, 2020Guide
Will ReadyNAS DUO fan speed quiet down after firmware update
I just factory reset my RNDuo v1 and updated the firmware RAIDiator 4.1.4 but the fan is still walloping at 5400 RPM. I could have sworn after the update there was a radio button or simialr switch in the GUI to control that.
How can I get the RN quiet again after this reset?
saxguy1 wrote:
I don't see any logs about sync status.
And the volume is redundant?
You could try the Enable Fan Min RPM add-on, as some have found that it also seems to solve the high-speed problem. No idea why that would work, but it is easy to try. Just make sure you don't set the min fan speed too low.
http://www.downloads.netgear.com/files/ReadyNAS/ADDON/4.1.3+/EnableFanMinRPMOverride_0.1
Why did you install 4.1.4? That's 12 years old.
Current 4.1.x firmware is 4.1.16. https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
- saxguy1Guide
I read on the forum that it addresed the loud fan issue.
I don't know what you read, but any fix in 4.1.4 would have been carried forward to 4.1.16.
I suggest reverting back to current firmware.
Was the fan running continuously at 5400 rpm? Was the NAS still syncing?
