teddis
Feb 13, 2018Aspirant
iTunes service does not start
Hi, I noted this problem back in June 2017 (
http://tinyurl.com/y9cfqeqh)
and saw someone else had the same problem two years ago
http://tinyurl.com/y9buxdk4
Can someone PLEASE help me get this working? It's not the browser. The iTunes service button either doesn't come on, or comes on briefly then turns off. I'm on latest firmware 6.9.2. This used to work a year ago. I forget which firmware version broke this. Thanks.
- teddisAspirant
Here are my logs showing "failed to start"
packages.log:ii forked-daapd 24.2-0.netgear1 armel DAAP/DACP (iTunes) server, support for AirPlay and Roku devices
systemctl-status.log:● forked-daapd.service loaded failed failed DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Stopped DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Failed to start DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:07 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:08 ReadyNAS systemd[1]: Stopped DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:08 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:08 ReadyNAS systemd[1]: Stopped DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.- teddisAspirant
Here's more from the log:
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] db: DB init error: trigger update_groups_new_file already exists
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] db: Could not create tables
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] main: Database init failed
- teddisAspirant
And here is my forked-daapd.conf file:
general {
# Username
uid = "media"
# Database location
db_path = "/apps/.forked-daapd/songs3.db"
# Available levels: fatal, log, warning, info, debug, spam
loglevel = log
# Admin password for the non-existent web interface
admin_password = "unused"
# Enable/disable IPv6
ipv6 = no
# Library configuration
library {
# Name of the library as displayed by the clients
# %h: hostname, %v: version
name = "ReadyNAS"
# TCP port to listen on. Default port is 3689 (daap)
port = 3689
# Password for the library. Optional.
#password = ""
# Directories to index
directories = { "/data/media" }
# Directories containing compilations
# Matches anywhere in the path (not a regexp, though)
# compilations = { "/compilations/" }
# Should iTunes metadata override ours?
# itunes_overrides = true
# Formats: mp4a, mp4v, mpeg, alac, flac, mpc, ogg, wma, wmal, wmav, aif, wav
# Formats that should never be transcoded
# no_transcode = { "alac", "mp4a" }
# Formats that should always be transcoded
# force_transcode = { "ogg", "flac" }
