ungovernable's avatar
ungovernable
Follower
Jan 15, 2012
Kensington lock for ReadyNAS Ultra 4
Can you recommend me a Kensington Lock that is compatible with the ReadyNAS Ultra 4 ? I bought a cheap laptop lock on ebay like this one:
http://www.ebay.com/itm/Laptop-Notebook-Security-Lock-4-HP-DELL-Apple-Sony-9801-/180790509041?pt=LH_DefaultDomain_0&hash=item2a17f43df1
It usually works on all locks like that but it doesn't work on my ReadyNAS U4, the lock will be loose and will easily get out.
What kind of lock are you guys using ?
Thanks
  • I know this is an old thread, but has anyone found a Kensington Lock compatible? I have the same problem with ReadyNAS NV+. The 3 Kensingtons I have do not work with it for various reasons (inset is too deep or there is nothing inside for the lock to press against).
ProSupport for Business
