RTFM11199
Jun 12, 2015Aspirant
Kernel panic after power outage NV+
Hi All, New User and been enjoying my ReadyNAS NV+ 4 x 2TB Drives for many years now. I suffered and outage and my NAS started playing up. (Unable to get into Setup, LCD not flashing IP Address ...
vandermerwe
Jun 12, 2015Master
Test the disks using vendor tools ( extended tests)
While you are doing that, factory default the nas with a spare known good disk in the chassis, obviously having removed and labelled the other disks.
What firmware is on?
Do you have a backup?
You could put all the disks into your friend's nas to test the array and/ or to retrieve your data. If you do this make sure all the disks are inserted with the nas off, and in the correct order. Make sure you update your friend's nas firmware to the latest version before doing this.
