RTFM11199
Jun 12, 2015Aspirant
Kernel panic after power outage NV+
Hi All, New User and been enjoying my ReadyNAS NV+ 4 x 2TB Drives for many years now. I suffered and outage and my NAS started playing up. (Unable to get into Setup, LCD not flashing IP Address ...
vandermerwe
Jun 12, 2015Master
You should use the disk manufacturers test tools, WD has lifeguard seagate has seatools.
The usb boot recovery is only appropriate when you have diagnosed that the firmware on the flash is corrupt. You haven't established that yet.
Kernel panic messages are non-specific and don't really help you, hence the advice I gave about the spare disk. If this procedure works then the flash is ok, if it doesn't then I would try a usb boot.
