smartwombat
Dec 19, 2012Aspirant
Kernel Panic
I received a new unit for my PSU failed NV+ today (FW 4.1.7). Plugged in the 4 disks (in the right order) and powered on. Came back a while later to see "Kernel Panic" on the LCD. Powered off and...
chirpa
Dec 19, 2012Luminary
Yes, flakey drive can cause a Kernel Panic.
Try booting without one of the disks inserted. If still panic, replace that disk, and remove the next one. Power off between add/removing the disks. Eventually you should boot up successfully with a failed drive notice. The drive removed at that point was the cause of the panic, RMA time.
