smartwombat
Dec 19, 2012Aspirant
Kernel Panic
I received a new unit for my PSU failed NV+ today (FW 4.1.7). Plugged in the 4 disks (in the right order) and powered on. Came back a while later to see "Kernel Panic" on the LCD. Powered off and...
Dec 20, 2012Guru - Experienced User
My advice on drives is to go with the WDC WD20EFRX.
Also I thought Seagate warranties back in 2010 were 3 years. You might use their warranty checker tool. However, they would send you a refurbished drive, and often don't replace it with the same model. So often I've done their RMA return, but used the replacement drive somewhere else...
BTW, a flakey SATA interface in the NAS could also be the cause. So it would be good to try Chirpa's procedure, and then confirm that it is in fact the disk.
