smartwombat
Dec 19, 2012Aspirant
Kernel Panic
I received a new unit for my PSU failed NV+ today (FW 4.1.7). Plugged in the 4 disks (in the right order) and powered on. Came back a while later to see "Kernel Panic" on the LCD. Powered off and...
smartwombat
Dec 20, 2012Aspirant
I've tested in two different brand new RMS NAS with the same result.
Both work with a new drive in slot 1 and no other drives.
Both fail with Kernel Panic with the disk set form my old 01ABBF unit.
So I'll try pulling disks one at a time.
Pulling disk 2 reduced the clicking - but gave a bad firmware error I tried to reinstall using the reset button.
Reinstall appeared to work, but then gave a Panic.
So I'll try 3, 4, and 1 to see what if any works.
No difference, removing any one of the 4 disks and attempting to boot now gives a Kernel Panic.
If there are two dead disks the array is dead - and it's the backup of the backup (NAS3 backs up NAS2 which backs up NAS1) so I don't have to worry :o
Just buy a new set of drives, hard drives are (expensive) consumables.
Drives ordered - that's my Xmas present sorted!
