notcounting's avatar
notcounting
Limit On Volume Count?
I have a readynas Ultra 6 unit that I am using in flex-raid mode. I added a new disk to the unit, and it recognized the disk as OK.
The problem is that it is not letting me add a new volume for the drive.
Is there a limit on the number of volumes available in a 6 bay unit?
  • notcounting wrote:
    Actually, I am a newcomer to the forum. I actually came to ask a question, which has been answered. I will poke around more to see what is up with the new OS.
    OS6 was a big change and was apparently rushed into production before it was ready, especially for the low-powered devices (the high-end x86-based boxes seemed to have fewer problems with the initial versions of OS6). Netgear has been working hard on the major showstopper bugs -- crashes and freezes, broken hardware, suboptimal filesystem configuration, incompatibility with the latest desktop operating systems, etc. -- and at this point those seem to have been fixed.
    So that's good, but there are still plenty of less-critical problems. The web interface has basic flaws: obvious configuration options that are inexplicably missing, non-orthogonal backup options (to be fair, that's a problem in OS4 as well), seemingly trivial features like disk spindown that were available on OS4 but are still missing from OS6, etc. I've deliberately chosen not to run OS6 on my old boxes because OS4 still works better... At least for my definition of "better".
    Anyway, welcome to the forum. I think you'll find a lot of interesting information here as you explore.
  • StephenB's avatar
    I've left my pro running OS4, but of course use OS6 on my RN102. I agree that the major showstopper type bugs have been fixed (including a couple in 6.1.7 beta).
    OS6 is still missing some features I use - in addition to disk spindown, you cannot send a WoL packet in a backup job, and you cannot schedule disk scrubs and volume scans.
    On the other hand, it includes some nice features that are missing in OS4 - including Antivirus, and more usable snapshots. It also will (sometimes) allow you to switch between flexraid and xraid w/o data loss.
    Both the x86 OS4 and OS6 manuals clearly state that a 6-bay NAS can have up to 6 volumes. If that it not really the case, Netgear should either (a) fix it in a maintenance release or (b) revise the manual. (a) would be my preference, since I think users expect the ability to run jbod on any home NAS.
    An alternative approach to getting more logical volumes would be iSCSI
    This is not encouraging about OS6. It sounds like it was released as beta quality, and they are playing catch up in the field.
    The limit is real. My guess is that someone in Marketing decided that they needed a 6 bay HW solution, but the software did not fully support it, and the company did not want to expend the engineering resources to fix the issues.
    This limit is a real problem because you cannot even create a volume to test a new drive. You basically cannot do anything with the drive until you add it to an existing volume.
    And, while we are at it, I hope that OS6 has better drive management support than OS4. OS4 lacks the ability to run targeted tests on drives, either offline, or using the SMART capabilities. Also, there is no way to wipe a drive which is being taken out of service. These are serious deficiencies.
    The diagnostic information provided when a drive fails is basically non-existent. The NAS is a little computer with drives in it. It needs the ability to fully test, manage, and diagnose failures which occur. Requiring someone to have a PC available which they can plug a failing drive into is not a valid solution.
    I looked at iSCSI. It is an inadequate solution:
    1) It is not a general file service.
    2) Not all client OSes support it natively, often requires 3rd party software.
    3) 2TB capacity limit is inadequate.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    OS4 had the volume names c d e and f hard coded into the OS, so adding support for 6 volumes would require manually adding some lines of code. With OS6 you name your own volumes and it is written in such a way to allow more volumes than you are likely to need.
    With OS4.2.x there is the disk test boot option, just like there is on OS6.
    OS4 runs a short online SMART test daily at 4am. You can do offline SMART tests manually if you really want to (it's just not something that's likely to be explained here).
    OK, but that is what software development is all about: "manually adding some lines of code".
    That's pretty heavy handed. There is no way to verify a new disk individually or test a failing drive and getting any real diagnostics out of the system.
    I have downloaded and examined the SMART logs on the unit. I see no evidence of this daily run. It looks like the short test is run once each time the disk is added to the unit.
    As to running SMART tests yourself, I assume you are talking about using SSH? I thought that was not allowed by support?
  • StephenB's avatar
    OS4 certainly monitors SMART, I have gotten alerts when reallocated sectors and some other stats change.
    On OS4 generally, it isn't getting new features, just maintenance updates. BTW, neither mdgm nor I work for Netgear.
    I realize it monitors the SMART parameters, but I don't see that it runs any tests regularly.
    I understand the status of OS4. However, they don't even seem to be qualifying new drives for the old configurations. That goes against the market in general. There are always new drives coming out, and old ones being discontinued. Soon, there will be NO drives on the market which have been qualified. What then?
    I understand that you guys are not employees, and I appreciate your experience and insight.
ProSupport for Business
