AbbottWins
Feb 06, 2014Follower
Limitations of RN51600
Hi all, Just to start I like to say that I have a four bay NV+ and a Ultra 6. I'm so happy with the units I am looking to get another unit, I'm looking getting the RN51600 this time but, before I ...
Feb 07, 2014Guru - Experienced User
dsnpevl wrote:
StephenB wrote: Storage units reported on the Web UI are TiB, not TB (1024*1024*1024*1042 bytes = 1 TiB)
StephenB wrote: 17.45 TiB is about 19,186,477,904,691 bytes (17.45*1024*1024*1024*1024)
That would be 19.19 TB (which is just power of 10). Your df command is reporting that also (19T)
So does that mean the units indicator "TB" (terabyte) doesn't match the value that is represented in TiB (tetibyte) for the "Data:" and "Free" fields (see picture below)?
But then the images of the disks with text "SATA 4 TB" do match the terabyte size of the disk. No wonder I get confused :) That would be an improvement point for the UI, I guess.
Proper labeling would be some improvement.
But the only way to really avoid confusion on TiB/TB would be for all manufacturers (disk vendors, apple, microsoft, NAS vendors ...) to use the same units. This issue has been around for decades, so I don't see it changing any time soon.
