AbbottWins
Feb 06, 2014Follower
Limitations of RN51600
Hi all, Just to start I like to say that I have a four bay NV+ and a Ultra 6. I'm so happy with the units I am looking to get another unit, I'm looking getting the RN51600 this time but, before I ...
Korky
May 30, 2014Aspirant
dsnpevl wrote:
StephenB wrote: Storage units reported on the Web UI are TiB, not TB (1024*1024*1024*1042 bytes = 1 TiB).
I always get a bit confused in this TiB vs TB issue. I was just qouting what I see on my screen. There it lists:data: 1.13 TB
free: 16.32 TB
StephenB wrote: Your volume seems to about 800 GB smaller than I'd expect.
1.13 TB + 16.32 TB = 17.45 TB. I rounded it down to 17 TB. Maybe that accounts for the difference?
root@nas-FF-FF-FF:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 1.3G 2.1G 38% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.3G 2.1G 38% /
tmpfs 1.9G 48K 1.9G 1% /dev/shm
tmpfs 1.9G 8.8M 1.9G 1% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
tmpfs 1.9G 0 1.9G 0% /media
/dev/md127 19T 1.2T 17T 7% /data
/dev/md127 19T 1.2T 17T 7% /home
/dev/md127 19T 1.2T 17T 7% /apps
I thought the Western Digital Re 4 TB [ WDC WD4000FYYZ-01UL1B0 ] wasn't supported by the 516. See https://www.readynas.com/forum/viewtopi ... 2&p=394874
So my question is how hot is your readynas 516 with 6 drives? I'm was about to purchase some of the same Disks until I came upon the above article :cry: Now that you have been using these hdrives in your NAS for some time any pointers or advice / recommendation you ( or anyone else ) can give me will be much appreciated.
I have checked the hd compatibility list and can confirm the above drive is not on the list. The next best drive is the Seagate 4 TB NAS HDD [ ST4000VN000-1H4168 ] is on the HCL.
Thanks in advance.
