AbbottWins
Feb 06, 2014Follower
Limitations of RN51600
Hi all, Just to start I like to say that I have a four bay NV+ and a Ultra 6. I'm so happy with the units I am looking to get another unit, I'm looking getting the RN51600 this time but, before I ...
Nov 22, 2014Guru - Experienced User
Thanks for sharing. Hopefully Netgear will include them in the HCL at some point.
dsnpevl wrote: ...To me it seems that these WDC WD4000FYYZ-01ULB0 4TB can be used without problems in RN516. Of course only time will tell if I'm right. It is true that the disks in the middle of the disk stack are always a couple degrees higher in temperature. Eventually, when the disks will get older, those might be the first to go. MTBF is 1.200.000 hours, so I should be good for a couple more years, I hope...
FYI, my pro-6 also shows some temperature variation by slot. So I think that is normal.
