boots1
Jul 24, 2011Aspirant
Lion breaks Spotlight searching
Since upgrading to Lion, Spotlight refuses to return results for my AFP mounted shares. Pro 6 with 4.2.18. I've been searching around for others reporting this issue but have drawn a blank. Could some...
lagreca
Aug 02, 2011Aspirant
ReadyNAS NV running RAIDiator 4.1.8-T5 [1.00a043]
I have the SAME problem. Searching my ReadyNAS shares work fine in 10.6.x, but once I boot into 10.7, they don't work correctly.
Here are some specifics:
10.7 can find a file directly within a folder. It can even find a file if your 1 or 2 levels out of that folder. But anything deeper, it doesn't seem to be able to find.
Not only that, but in 10.7 there is NO indicator that the search is running or has ended, so you are just left guessing as to what is going on...
