StuBarrett1
Jun 26, 2019Aspirant
Loading data into ReadyNAS using esata port
Migrating data from my ReadyNAS-Pro to my new 424 box and I have a large amount of data that I backed up onto a single larg disk. Is there anyway to take that disk, attach it to the esata port on...
Marc_V
Jul 01, 2019NETGEAR Employee Retired
If that disk is not a part of the RAID from your old ReadyNAS Pro then it would be just fine to attach it to an eSATA enclosure, it will be detected by the NAS. However, If it's configured on a RAID even if it's on JBOD it would not start over USB port or eSATA.
it might be good if you backup the data from the old NAS using an external USB drive then use that on the new NAS.
HTH
Regards
