georgejzeck7244
Apr 18, 2013Aspirant
Local Firmware Failed ?
Hi All - I recently downloaded "RAIDiator-arm 5.3.5" onto my PC and through the frontview panel / system / upgrade attempted to upgrade the firmware (It's likely been years since I did it last). I ...
Apr 18, 2013Guru - Experienced User
If you did it "years ago" then you are trying to install v2 firmware on a v1 product. Please confirm your platform here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If you have a v1, then you need 4.1.x firmware. 5.x.x won't work.
Note: I deleted your duplicate posts.
