unkis17
Aug 02, 2014Aspirant
Locked out of Duo
Hey all, First time poster here, helping a friend with a DUO. I set this up for him over 3 yrs ago and now he tells me he can't get in (since he moved and changed routers) and he doesn't have a ...
mdgm-ntgr
Aug 03, 2014NETGEAR Employee Retired
You should backup across your network. You can't use a 3TB USB drive with the v1. The v1 only supports disks up to 2TB in capacity for both internal and external disks so backing up across your network is the way to go.
