hinze555
May 09, 2017Aspirant
Lose LDAP Connection - Active Directory Domain Services
HI! I've just upgraded to FWV 6.7.1 to check if that issue persists - it does. Since a few days we have an event on the server logs from the active directory domain service, that the Readynas l...
- May 12, 2017
Hi Jenn!
The error started a few weeks ago. It did not work with the prvious version of the RN Firmware.
I asume it is some kind of windows issue - though it is harmless acording th this MS Article: https://support.microsoft.com/en-us/help/246717/numerous-event-id-1216-events-in-directory-services-event-log
Maybe it disapears as it apeared... :)
Hinze
JennC
May 11, 2017NETGEAR Employee Retired
Hello hinze555,
Was this working flawlessly prior to update to 6.7.1?
Please send system logs and include the link to this topic with a short summary of the problem.
Welcome to the community!
- hinze555May 12, 2017Aspirant
Hi Jenn!
Hinze
- JennCMay 12, 2017NETGEAR Employee Retired
Hello hinze555,
It occurs only if the diagnostic logging level is increased by modifying the level of LDAP logging to 2 or above in the registry.
So, I checked the link, yes, it appears to be something with Windows and harmless. I guess for now, we may consider this topic close.
Thank you for sending the link, by the way.
- JennCMay 15, 2017NETGEAR Employee Retired
Hello hinze555,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
