hinze555
May 09, 2017Aspirant
Lose LDAP Connection - Active Directory Domain Services
HI! I've just upgraded to FWV 6.7.1 to check if that issue persists - it does. Since a few days we have an event on the server logs from the active directory domain service, that the Readynas l...
- May 12, 2017
Hi Jenn!
The error started a few weeks ago. It did not work with the prvious version of the RN Firmware.
I asume it is some kind of windows issue - though it is harmless acording th this MS Article: https://support.microsoft.com/en-us/help/246717/numerous-event-id-1216-events-in-directory-services-event-log
Maybe it disapears as it apeared... :)
Hinze
hinze555
May 12, 2017Aspirant
Hi Jenn!
Hinze
JennC
May 12, 2017NETGEAR Employee Retired
Hello hinze555,
It occurs only if the diagnostic logging level is increased by modifying the level of LDAP logging to 2 or above in the registry.
So, I checked the link, yes, it appears to be something with Windows and harmless. I guess for now, we may consider this topic close.
Thank you for sending the link, by the way.
