zhenya
Jan 16, 2015Aspirant
losing connection to ReadyNAS Duo
I am running ReadyNAS DUO and lately started experiencing connection issues. All of sudden I can't access my shares from any system on the network. I am getting the following error. ---------------...
Jan 17, 2015Guru - Experienced User
Do you have ssh enabled on the duo? What add-ins are installed? Are you using DLNA?
Intermittent connection loss could be an early sign that the OS partition (not the data partition) is filling. That can be fixed.
Though if you don't have a full backup of the data, you should make one.
