zhenya
Jan 16, 2015Aspirant
losing connection to ReadyNAS Duo
I am running ReadyNAS DUO and lately started experiencing connection issues. All of sudden I can't access my shares from any system on the network. I am getting the following error. ---------------...
Jan 18, 2015Guru - Experienced User
It is installed, there is nothing to configure. If you install it again, it switches the cache back to the OS partition (which you don't want). Netgear calls this kind of add-on a "toggle".
Now that you have ssh installed, try logging in with putty and entering
and let us know what it says.
df -h /
df -i /
