zhenya
Jan 16, 2015Aspirant
losing connection to ReadyNAS Duo
I am running ReadyNAS DUO and lately started experiencing connection issues. All of sudden I can't access my shares from any system on the network. I am getting the following error. ---------------...
zhenya
Jan 19, 2015Aspirant
Thank you Stephen. I found the offending file upnp-av.log was nearly 1.6Gb. Here is the new output. Hopefully this solves the problem. Thank you for your help.
ReadyNAS:/# df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 410M 1.5G 21% /
ReadyNAS:/# df -i /
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 256000 14708 241292 6% /
ReadyNAS:/# df -h /
ReadyNAS:/# df -i /
