rdorian
Nov 18, 2014Aspirant
Losing Volume on Raid 0 #24221687
Hi I have a strange issue with losing my volume after the first NAS restart after initial set-up. All 4 drives check out fine in Windows, memory test and disk checks have been done via the NAS and ...
rdorian
Dec 06, 2014Aspirant
Hi
Ok, I put my 4 drives back in the NAS, did a factory reset, installed SSH, restarted and lost my volume as expected...all 4 drives are visible by the NAS and reporting with no faults.
Ran the commands on the link that you referred to but received the below errors:
Is ~# normal for the shell that the ARM ReadyNAS uses? I’m guessing it is as the commands run, I used mobaxterm and putty just to make sure that it wasn’t the client software.
Also for anyone else installing the SSH add-on for the NV+V2, it doesn’t show in the installed add-on list for some reason... took 4 hours to figure that one out, as I assumed that the install kept failing.
Any idea what this “Inappropriate ioctl for device” error is in relation the ReadyNAS? Any other pointers?
I’m at a loss at this point.
Once again, thanks for your time guys. It’s people like you that donate your free time to help others that makes the internet.
login as: root
root@NASBackup's password:
Linux NASBackup 2.6.31.8.nv+v2 #1 Thu Apr 18 17:40:54 HKT 2013 armv5tel GNU/Linux
Last login: Sat Dec 6 17:04:59 2014 from surfacepro
root@NASBackup:~# hdparm --security-unlock NETGEAR /dev/???
security_password="NETGEAR"
/dev/bus:
Issuing SECURITY_UNLOCK command, password="NETGEAR", user=user
SECURITY_UNLOCK: Inappropriate ioctl for device
root@NASBackup:~# hdparm --security-disable NETGEAR /dev/???
/dev/bus:
Issuing SECURITY_DISABLE command, password="NETGEAR", user=user
root@NASBackup:~#
