rdorian
Nov 18, 2014Aspirant
Losing Volume on Raid 0 #24221687
Hi I have a strange issue with losing my volume after the first NAS restart after initial set-up. All 4 drives check out fine in Windows, memory test and disk checks have been done via the NAS and ...
rdorian
Dec 06, 2014Aspirant
Hi
Ahhh. I thought that it was some kind of crazy wildcard for the command.
The only drive identifier that I have is md0, keeping in mind that I'm raid 0 (4x4TB all recognised in the dashboard).
Am I doing something silly?
Linux NASBackup 2.6.31.8.nv+v2 #1 Thu Apr 18 17:40:54 HKT 2013 armv5tel GNU/Linux
Last login: Sat Dec 6 19:14:30 2014 from 192.168.0.19
root@NASBackup:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 535M 3.3G 14% /
tmpfs 16K 0 16K 0% /USB
tmpfs 50M 0 50M 0% /var/replicate/shm
root@NASBackup:~# fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 4000.8 GB, 4000787030016 bytes
256 heads, 63 sectors/track, 484501 cylinders
Units = cylinders of 16128 * 512 = 8257536 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 266306 2147483647+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders
Disk /dev/md1 doesn't contain a valid partition table
root@NASBackup:~# hdparm --security-unlock NETGEAR /dev/md0
security_password="NETGEAR"
/dev/md0:
Issuing SECURITY_UNLOCK command, password="NETGEAR", user=user
The running kernel lacks CONFIG_IDE_TASK_IOCTL support for this device.
SECURITY_UNLOCK: Invalid argument
root@NASBackup:~# hdparm --security-disable NETGEAR /dev/md0
/dev/md0:
Issuing SECURITY_DISABLE command, password="NETGEAR", user=user
root@NASBackup:~#
