RonLuxton
Apr 18, 2013Tutor
Lost my shares
ReadyNAS NV+ connected through network to 2 Ethernet-connected Windows 7 (64 bit) PCs, and one wireless-connected Windows 7 (64bit) laptop. 28 Shares (mainly household accounts,banking details et...
JohnWB
Apr 27, 2013Aspirant
StephenB wrote: This is a browser problem.
I suspect you are running IE10? If so, you need to use compatibility mode in the browser.
Or switch to chrome/firefox.
Stephen B, thanks for that
I have exactly the same problem since changing to IE10, your trick worked perfectly.
You have just saved me having to try a complete reinstall :D
