pxpioneer2
Mar 22, 2025Tutor
Lost my Volume Readynas 3138 Pulled Drives
I have a ReadyNAS 3138 and had 2 drives pulled in an ill advised attempt to stop a beeping noise. Turned out that the beeping came from a UPS, whole other story. During the attempts I pulled two...
- Mar 22, 2025
I made a good number of mistakes in this process. All I can do is be open and honest in my error and hope for the best. PM sent.
Mar 22, 2025Guru - Experienced User
pxpioneer2 wrote:
I have seen several tutorials on using SSH and am looking to simply recover the Volume. All disks show being part of data-0 and the group data-0 shows the correct 27.27tb. It does show zero free space. There is another volume of zero size called data.
Any help or guidance is appreciated!
Reboot up the system with all disks in place. Then download the full log zip file from the admin web logs page.
If you'd like me to analyze the zip file, then upload it to cloud storage (dropbox, google drive etc). Send me a PM (private message) with a link to the zip. Make sure the permissions are set so anyone with the link can download. Note you send a PM using the envelope icon in the upper right of the forum page.
Don't post the link publicly, as there is some privacy leakage when you do that.
pxpioneer2 wrote:
Feb 24, 2025 06:57:34 PM Disk: Disk Model:ST10000NM0016-1TT101 Serial:ZA2BSYCG was added to Channel 2 of the head unit.
Feb 24, 2025 06:56:58 PM Disk: Disk Model:ST10000NM0016-1TT101 Serial:ZA2B5GQM was added to Channel 1 of the head unit.
FYI, hot-inserting the two disks you removed was also a mistake.
pxpioneer2
Mar 22, 2025Tutor
StevenB absolute legend! He was able to guide me through the correct parameters to rebuild my Volume. I am currently resynching. Lesson #1 don't pull drives. Lesson #2 don't listen to your local experts.
Just a big blessing to have a resource like this when Netgear is done supporting a project!
- StephenBMar 23, 2025Guru - Experienced User
I'm glad I could help.
