h_tsopelas
Nov 08, 2015Aspirant
Low internet connection after ftp share
Good morning, I have made some accounts with ftp and give access ReadyNas102. The problem is that my internet now go very slowly. It is possible to give only a fraction of the speed of the internet s...
Nov 08, 2015Guru - Experienced User
Are you saying that FTP over the internet is slow?
Or that all your internet access (PC browsing, everything) became slow after you enabled FTP on the NAS?
h_tsopelas
All my internet became slow after you enabled FTP on the NAS
- StephenBNov 08, 2015Guru - Experienced User
And if you disable it, does it speed up again?
- h_tsopelasNov 08, 2015Aspirant
Yes, if i disable it, then everything is ok again.
Odd. Are FTP ports forwarded in the router? If so, try disabling the forwarding, and re-enable FTP in the NAS and see what happens.
