joe_wht's avatar
joe_wht
Luminary
Nov 03, 2016
Mac OS users/ login servers not logging in completely
My old Macbook Pro would startup & connect with my RN214 perfectly before. I only had my " Pictures " folder in the " Login " server and then I could easily click on any Finder Favorite ReadyNAS fo...
  • StephenB's avatar
    Nov 07, 2016
    Volumes can't be renamed.  You'd have to enable flexraid (if it's not already enabled), destroy the volume, create a new one, and then restore the contents.
    If its the only volume, uninstall all apps before doing this.
ProSupport for Business
