Kneelb4z0d's avatar
Kneelb4z0d
management system is offline again
hi, so ive had my readynas system for a little over two months now and im still having problem i have sent logs in a few times to try and resolve it but no suggestion seems to fix it.   just about ...
  • mdgm-ntgr's avatar
    Jun 17, 2016
    Your logs are showing that your system is OOMing. Plex is using a lot of memory. You may wish to contact support as StephenB suggested.
    It looks like you have two different versions of Plex installed.
ProSupport for Business
