Kneelb4z0d
Jun 17, 2016Aspirant
management system is offline again
hi, so ive had my readynas system for a little over two months now and im still having problem i have sent logs in a few times to try and resolve it but no suggestion seems to fix it. just about ...
- Jun 17, 2016
Your logs are showing that your system is OOMing. Plex is using a lot of memory. You may wish to contact support as StephenB suggested.
It looks like you have two different versions of Plex installed.
mdgm-ntgr
Jun 17, 2016NETGEAR Employee Retired
Kneelb4z0d
Jul 08, 2016Aspirant
so after your post i removed plex for a few days to see if it that would help it. and it has it hasnt gone offline since which is much better. the main reason why i opted for this model is because of plex. so hopefully the guys at plex can figure out what the issue is and fix it for another release.
for now ive put plex on the pc and set it to read from the nas so its not all bad.
thanks for the help
