F_L_
Feb 22, 2014Tutor
Manually create SMB and NFS share
I´ve managed to create my own SMB-share in /etc/frontview/samba/Shares.conf and /etc/frontview/samba/addons/addons.conf This seems to work. But what is the proper what to add it as NFS? Runnin...
fastfwd
Feb 23, 2014Virtuoso
F.L. wrote: Problem is that the entry in etc/export doesn't stick after a NFS toggle in Frontview.
When you say "after an NFS toggle", do you mean "after disabling NFS in Services:Standard File Protocols, hitting Apply, then re-enabling NFS and hitting Apply again"? On my system, the share disappears when the NFS server is disabled, but then reappears in the exportfs list when NFS is re-enabled.
