F_L_
Feb 22, 2014Tutor
Manually create SMB and NFS share
I´ve managed to create my own SMB-share in /etc/frontview/samba/Shares.conf and /etc/frontview/samba/addons/addons.conf This seems to work. But what is the proper what to add it as NFS? Runnin...
Feb 23, 2014Guru - Experienced User
Got it. If you create FolderToShare in Frontview, then you have a couple other options to try.
(a) simply move \data\dir1\dir2\FolderToShare into \data\FolderToShare. That obviously works, but you end up with only one path to FolderToShare. That's what I would do.
(b) You can also try deleting \data\FolderToShare from ssh (after you create it), and then create a soft link to \data\dir1\dir2\FolderToShare. I am not sure if that will work, but it is easy to try.
