Zapoteknico
Apr 08, 2022Aspirant
Microsoft EDGE - Readynas keeps going to password recovery
When I try to access my Ready Nass from a Microsoft Surface with EDGE it always go automatically on the Password reset page. If i try to do the same using Internet Explorer, it works no problem. Th...
Apr 08, 2022Guru - Experienced User
Have you tried both https://nasname/admin or https://nasipaddress/admin ? (using the real NAS name and IP address of course).
This sounds like Edge might have saved an old or incorrect password. It would apply that automatically, and if it is wrong you could end up on the password reset screen. You can test this by opening an inPrivate window, and log in from there. Or just browse to edge://settings/passwords and look for saved passwords for the NAS there.
Zapoteknico
Thank you. For your answer.
None of the suggestions works and I have no passwords saved, even using private mode i receive the message attached
- StephenBApr 08, 2022Guru - Experienced User
What model ReadyNAS do you have, and what firmware is it running?
You will get a certificate warning (which is what the "your connection isn't private" bit is about). But usually "advanced" gives you the option to connect anyway - and you aren't seeing that.
BTW, there is an IE mode built into Edge that you could try. But I think we still should try to get Edge to connect w/o it. More info on IE mode is here: https://docs.microsoft.com/en-us/deployedge/edge-ie-mode-local-site-list
