Zapoteknico
Apr 08, 2022Aspirant
Microsoft EDGE - Readynas keeps going to password recovery
When I try to access my Ready Nass from a Microsoft Surface with EDGE it always go automatically on the Password reset page. If i try to do the same using Internet Explorer, it works no problem. Th...
Zapoteknico
Thank you. For your answer.
None of the suggestions works and I have no passwords saved, even using private mode i receive the message attached
Apr 08, 2022Guru - Experienced User
What model ReadyNAS do you have, and what firmware is it running?
You will get a certificate warning (which is what the "your connection isn't private" bit is about). But usually "advanced" gives you the option to connect anyway - and you aren't seeing that.
BTW, there is an IE mode built into Edge that you could try. But I think we still should try to get Edge to connect w/o it. More info on IE mode is here: https://docs.microsoft.com/en-us/deployedge/edge-ie-mode-local-site-list
